Old 07-20-2019, 04:03 PM   #10
Box7774
Hello all.......Well its been hotter then I can remember around here.....havent been out in the garage as much as I would like to fix the window issue. But I have been doing my homework while not doing much actual work on the car. Given that my cables are tight and that I have the double beep and interior lights that come on and go off at odd times.......Like PW originally suggested I am much more confident that my door switch needs to be replaced vs the ole zip tie trick. I purchased and received the 101 Projects for a Boxster book and it pinpoints the switch that is causing my issue seen in purple arrow in included pic. Now this book doesnt go much further into how to replace that switch .........so I am asking you guys......How do I replace just that switch?
I will say that my window zips right up when I shut the door so that switch is good. My windows also zip right down when i open the top...so that switch is good. Its just the switch from opening the outside door handle.
Box7774 is offline   Reply With Quote
