With all four wheels on the ground, go from wheel to wheel and push and pull as hard as you can at the top of the tire. If you feel a slight clunk you have found a worn wheel bearing. Try this both when the car is cold and also just after it has warmed up.
1941 Dodge Luxury Liner Coupe
