Old 07-19-2019, 06:42 PM   #10
dghii
Originally Posted by bekks View Post
I checked closely to make sure nothing was rubbing (with the wheel off, then the brake pads out, then the disc/drum off). As I mentioned, there was a little sound that went away after cleaning out the drum, but that was not my main problem. Cornering one way now seems to exacerbate it a bit, so the bearing is looking more likely. As well as the fact that I cannot replicate the sound with the wheels unloaded.
I have a good wall to drive along on my way home today, so I will confirm which side it is coming from and then order the bearing.
I think almost all of us that have had this kind of noise hunts and hunts, wonders and wonders, and then finds replacing the bearing solves all.
Your car is at an age and mileage that the bearings are suspect. Get them change and motor on!
