I've not used the CG Lock, as you can get the standard 3 point seat belt to hold you in place with a simple trick:
1. Slide the seat all the way back.
2. Put on the seat belt.
3. Pull seat belt tight as you can around you and tug on it so it locks. Keep tension on it so it stays locked.
4. Slide the seat forward until the belt is tight against you. The belt should be a little uncomfortable when it's this tight.
It's definitely not a race harness, but it's also free. I've found it to be a fantastic solution to keep me from sliding around the seat, or hanging on to the steering wheel to stay in the seat while on track.
1999 Boxster
2013 Carrera
