Old 07-17-2019, 09:08 AM   #1
Superbike81
Been busy the last couple of weeks.
- Feal Coilovers installed (actually only driver's side so far, should finish the rest this weekend)
- Gloss white vinyl wrap mostly complete, need to clean up a couple areas.
- Etsy sourced Martini livery/graphics were a big fail, quality was not good and side stripes weren't even long enough, hunting for a local shop to do it for me.
- Ordered Tarett front/rear drop-links, Rennline toe arms, Rennline wheel studs, H&R 7mm spacers rear & 15mm spacers front (will remove for track use), Rennline tow hook, and a few other little things.
- Plastidipped wheels red, if I end up liking it enough I'll powdercoat them red next time I have to do a tire change.
- Hawk brake pads front and rear
- Ended up changing directions on the seats, went with something less aggressive (Corbeau RRX)
- Lots of little maintenance items, checking torque specs, flushed brake fluid, etc
Hoping to finish installing all the suspension stuff this weekend so I can get the car in for an alignment. The rear suspension install is a pain in the butt.
Superbike81 is offline   Reply With Quote
