Thread: My daily driver
Old 07-11-2019, 06:58 PM   #8
Qingdao
Qingdao's Avatar
Originally Posted by obthomas View Post
DONE:dance:
4 new wheel bearings, 4 new struts, all new control arms, all new radius links, all new tie rods, all new sway bushings and sway bar links. Good for another 100K miles
I really can't think of any thing I would do different. A couple of things I learned, There is no castor adjustment on this car. No matter how close you measure the steering tie rods old you still got an off center steering wheel. I'm not sure my marks and camber adjustments are very good either. Its off to the alignment shop.
I am a mechanical engineer by trade and a pretty good shade tree mechanic and I tell you this to give weight to the next piece of data.
With a good set of tools this job took me 27 hours.
Its been about a year or so since I've had a Porsche on the rack, but if I recall correctly the rear point of attachment on the front LCA is positioned so you can adjust castor.
Your alignment guy should be able to adjust it regardless.
Lots of shops stray away from working on exotics like this car, but when I had to put a new rack in I found it really easy even compared to typical cars (IE Camry).
'98 PP13B powered "RX986"
