Old 10-05-2006, 07:31 AM   #6
Adam
Originally Posted by John V
You should NEVER have to add more fluid. Just flush it once a year (minimum).
That's not true, as the clutch disc and brake pads wear the fluid level in the master cylinder will go down and adding some quality dot 4 fluid is fine. Also, once a year flush is too often unless you are doing track work on a regular basis. For standard driving, a flush every two years is more than enough and what Porsche recammends.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
