Old 07-06-2019, 08:54 AM   #2
Xcellr8
Center radiator parts
Hi Monty,
I have the parts you are looking for, but, yes, there is always a but, the lower portion of the radiator bracket is bent from running over a small boulder during an off road shunt. As you probably know, the bracket is thin steel. It bends easily. This bracket is usable, but may need a bit of tweaking. If this is something you can accept, I'll snap some photos.
In total, I have the following;
-Center radiator from a different car in very good conditon - I understand you already have this,
-Center radiator two part mounting bracket with 4 mounting bolts, and the two speed nuts and bolts (condition as described above.)
-Center radiator rubber air duct (I have two). Interestingly they both carry the same part number, but one has rubber tits that go into the mounting bracket, while the other duct has holes that would require a fastener to attach the duct to the bracket. Given the condition of the lower bracket, I think the second duct might be the better choice as the rubber tits are not substantial enough to stay in place due to the less than perfect fit of the bent bracket.
-New center radiator hoses - you didn't mention these in your request, so I'm assuming you already have them. No clamps are included.
- A front bumper plastic center radiator opening. This too came off the crashed vehicle and I can't fully determine if it is usable, but at a minimum, it would be an excellent template if you need to cut an opening in the bumper cover.
I had intended this to be a complete center radiator kit.
Let me know if/how you want to proceed.
Thanks,
Joe
Xcellr8 is offline   Reply With Quote
