Old 07-06-2019, 08:07 AM   #11
Fuzzuki
It's located on the left side below the intake. Most likely connected by a clamp with a 8mm bolt to the intake. The flexible tube from the throttle body clamps onto the valve. The semi rigid tubing that comes with it goes forward, then down to the belly where there is a 'squeeze to release' connector.
EDIT:*** The part that KRAM linked the part number for is *not* the part that I'm showing. I'm showing the "regeneration valve" from the thread that Monty linked. This: https://www.pelicanparts.com/More_Info/99611012906.htm?pn=996-110-129-06-OEM , "99611012906"
Will go order the part today.
Is this readily accessible?
Do I need to take anything off before I can get to this part?
Fuzzuki is offline   Reply With Quote
