Old 07-05-2019, 01:33 PM   #10
Homeoboxter
Hi Markus,
No, I haven`t yet, but I was gonna drop it off at some machine shop to have it checked. Or I`ll just place it down on a glass table and meaure the gaps all around with a feeler gauge. I`m kind of far from that stage yet though.
Best,
Greg
Hi,
have you measured the cylinder heads to be absolutely flat? Most times it's needed to plan the surface, because they aren't 100% flat at all. And if the surface isn't absolutely flat you'll run into problems with leaking cylinder heads (oil and water). So all the effort will be worth nothing if you miss this step.
Regards from Germany,
Markus
