Old 07-05-2019, 05:32 AM   #1
Smallblock454
Hi,
have you measured the cylinder heads to be absolutely flat? Most times it's needed to plan the surface, because they aren't 100% flat at all. And if the surface isn't absolutely flat you'll run into problems with leaking cylinder heads (oil and water). So all the effort will be worth nothing if you miss this step.
Regards from Germany,
Markus
Smallblock454 is online now   Reply With Quote
