Old 07-02-2019, 03:30 PM   #2
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by gti13 View Post
Okay so Line G is if you have an Automatic transmission? if so I have a 5 speed Manual
In the diagram, (G) is a 3-way and you should have two 3-way connectors on a 2000 or later manual trans 986. The Tip' will have a 3-way and a 4-way. Your other 3-way should probably be on or near (F), the vacuum reservoir.
L should plug into the passenger side throttle body pipe, ill have to look for this as I dont remember seeing this but I will double check
(L) is the rubber coupling on the intake that has a small hole that (H) or a piece of the smaller more rigid tubing can poke into.
The arrow is pointing to (L), where (H) should be connected either directly or with a small piece of tubing:
Last edited by 78F350; 07-02-2019 at 03:36 PM. Reason: Added pic from another post
