Old 07-02-2019, 09:50 AM   #1
truegearhead
truegearhead's Avatar
Originally Posted by Quadcammer View Post
You can probably bolt up the 2.5 intake to that and make it a direct swap although you will likely lose a bit of power.
If you keep 2.7 intake you will need a custom intake tube, and to repin the ecu for the resonance valve
Thanks, re-pin the ECU for the resonance valve? Do you know if there’s a write up on this? Re-pinning the ECU doesn’t sound like an easy one.
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
