Old 07-01-2019, 10:27 AM   #1
1stSP
Windows don't work
I just replaced the window regulator. When I open and close the door, the window moves a half inch as it should. But, when I push the window button on the console nothing happens. When I release the lever for the top the windows do not go down. The door lock does not work either when I push the button on the key. Does anyone have any ideas ?
Also, I removed the passenger door panel to check if the airbag was connected and in doing so I broke a small switch that goes through the panel to the inside door lever. It looks like a small light. It is one of two small connectors right behind the lever to open the door. Does anyone know what these connectors are for.
1stSP is offline   Reply With Quote
