Old 06-30-2019, 05:09 PM   #5
blue62
"IF you decide to try to start it and it will start and run then as Particlewave suggested put a durametric or other scanner on it that can read live data and see if you can find anything amiss.
Other things to look at:
You "may" have a bad ground or relay that is affecting the DME signal
"IF" you decide to try to start it and it cranks but does not start or even fire.
You could spray a little starting fluid into the intake just to see if it will fire or not.
If it fires on the starting fluid I would look in the direction of fuel related issues.
If it does not fire on the starting fluid I would look in the direction of spark related issues.
