Old 06-27-2019, 05:29 PM   #12
BoxMann
The A/C compressor only consumes about 2-3hp which is not very much unless you have one that is failing. Then it will add significantly more load.
I sure hope that's not the problem. IIRC, a new a/c compressor is something like a $4,000 job.
Hot weather has a much greater effect on performance than running the A/C in my testing. Once the car becomes heat-soaked I may give up 2-3 seconds per lap due to both engine and tire grip losses. My personal best laps always happen with plenty of cold air at the intake when ambient temps are 50-60F here in SoCal.
Interesting. Come to think of it, I started noticing it when the weather turned hot. OTOH, I started using the a/c when the weather turned hot.
2004 Boxster S, 6 spd, Triple Black
1986 944 Turbo (sold in 1988)
Since then, a 300ZX, a few BMW 3 Series, a few VW's
BoxMann is offline   Reply With Quote
