Old 06-27-2019, 06:30 AM   #1
blue62
Originally Posted by Geir Nordvik View Post
So, I started a hunt to find the cause for the whing sound from the rear compartment.
I was thinking that a good start was to take look at the belt rollers. They did look quite tired when I spinned them.
Today I changed all three of them. No change in whining noice, but now at least I hve new rollers..
Thinking what will be next attemp.
Problem is:
Hearing a whining noise that sound like something rotating. Like a fan maybe.
- It is only possible to hear when driving.
- If I press inn the clutch, noise stops.
- The sound are higher when rev is higher.
Was thinking of something with the transmission, but since it follows the rev I'm confused.
Happy for all input tips
A bad or failing Alternator can sometimes make a whining noise. It would change with RPM. You my not hear it when you press the clutch in because as RPM drops noise level drops.
My only other thought would be your throw out bearing is going. But I think they make noise when the clutch is pressed which is opposite of what your experiencing.
