Old 06-23-2019, 08:49 PM   #22
blue62
Originally Posted by Box7774 View Post
Ok will do.......I am pretty sure both windows do go down when I go to lower the top....so I assumed that feature was working for when I put the top back up. I will read up and figure it out....thanks
You mentioned in one of your first few posts that your battery only held 12.3 volts after a 3 hour drive the day before testing.
your thought was that you may have a parasitic draw.
12.3 volts is a 30% charge.
If after driving for three hours you have less then 12.5 volts or higher something is wrong.
A battery that is not charging or holding proper charge can cause all kinds of strange little electrical problems.
May I suggest you make certain the battery is charging and holding sufficient charge before looking to other electrical problems.
Starting with the simplest most basic. (main power source=battery) Then working step by step to the more complex helps reduce the chasing of ones own tail.
