Old 06-23-2019, 01:00 PM   #10
piper6909
piper6909's Avatar
Just finished replacing the water pump, thermostat, oil cooler seals and trailing arm links (tuning forks).
The PITA bolt on the water pump wasn't so bad. My Craftsman 1/4" drive with an 8mm deep-well socket fit in there perfectly to break the bolt loose.
The I used a regular socket with a Harbor Freight swivel attachment to pull it the rest of the way by hand.
In addition to a bit of play on the pulley, once I got the pump off I noticed some crustiness, looks like it may have started to leak from the weep hole.
But the impeller was intact! :dance:
Turns out this must have been the original pump, since the gasket was never cut. Not bad for 91K miles, I guess. (although yesterday I changed the WP on my Dodge Grand Caravan with 163K miles and it, too was original)
The new gasket got a little janked up during shipment. When I first started the car I had a little coolant weeping at the gasket, but after re-torquing the bolts it seems to be holding. I'll have to keep an eye on it for a while.
And no more annoying clunking when I go over bumps with the new tuning forks! :dance:
