Thanks ANKER......Im no mechanic but I am good at the basics.....I have a Multi meter....will try your tests. When I purchased the car it would barely start on a weak battery and the bendix would squeal every other start or so. The batt was at 12.3 volts engine off after a 3hour drive the day before. I put the batt on a trickle charger to achieve a full charge. After charged the bendix still squealed but the starter spun the motor much faster. I am trying to see if I have some kind of parasitic drain.....or like you said maybe its the alternator or voltage regulator.
