Hi Forum,
thanks a lot for all your ideas and suggestions.
I changed the AOS and the Vacuum line going from the top of the AOS to the inlet near the throttle body.
This cured the issue.
Please be aware that I got a newer type AOS where the tiop round part I vertical vs my old one where it is Horisontal.
The vacuum line with the new AOS has to be a few cm longer. I initially got the original one which turned out to be to short . the longer one was 996.107.145.06 whereas the older shorter one was 05 at the end.
BR
Kim
