Old 06-21-2019, 03:56 AM   #7
Cosmo Kramer
Check out the spark plug from Cylinder 1. The pieces of metal in the oil pan were piston skirt not IMS bearing. Looks like the piston blew apart. I fished around through the spark plug hole with a screwdriver the the piston has a huge crack though the crown. Probably the cylinder is cracked too. Very surprised this engine still started up.
Donor car will be going on the lift next for engine/trans removal.
Cosmo Kramer is offline   Reply With Quote
