Old 06-20-2019, 09:23 PM   #330
particlewave
Questions:
Is that little gaze mat, which was underneath the HAES Sub, necessary for a 2-way speaker?
Should the Speaker be able to breath/vent heavily or should it be completely air sealed?
It sounds already good, but want to create the best possible circumstances for the speaker.
Any expert tips?
You'll need to refer to the speaker manufacturers recommendations regarding sealed vs ported and enclosure volume.
Generally speaking, for better response from smaller mid range to sub speakers, you want the enclosure sealed and some insulation inside as the enclosure volume is likely inadequate.
Also, with your gap (port) so close to the cone, you're going to lose a lot of low end to phase cancellation (and a 6.5" speaker isn't going to have much low end to begin with).
Definitely seal that up.
