					Originally Posted by  pahanorlando
				Thanks do you use OEM mount replacement?
I just replaced the center part.
 It has to be pressed in so you will need access to a hydraulic press. If you go that route.
 The OEM part is the entire mount and is around  $175.00 the center part is around $20.00-$40.00
depending on brand. replace the rubber side buffers  also. They are around $15.00
 If you look at the parts you will see what I am referring to.
