Originally Posted by Duke0594
This mechanic was referred by a friend. I will not go back.
The front brakes are locking up after about 6 miles of driving. The back ones are getting hot but not nearly as bad as the front.
This mechanic said that they had the calipers off and the pistons were going in and out like they were supposed to. I've talked to another guy who had the same problem. Looked at the calipers and were working. They ended up putting new calipers on and low and behold that fixed the problem.
I have found some reman calipers. Think that's the next step. Will definitely let 8know the outcome.
so this brings up a question I have...I have the Boxster S and should I want to rebuild the calipers, the kits are unreasonably expensive.
Aren't these 4 piston Brembo?
36mm/40mm Front Pistons
28mm/30mm Rear Pistons?
why cant I just get a brembo rebuild kit in the proper caliper sizes? Is there an alternative to the kits anyone can turn us onto?
