					Originally Posted by  piper6909
				That's something I hadn't thought of doing.  I'm guessing you mean the front mount?  Is that also referred to as the center mount?  What do you think of the URO mount?  It's cheap enough, but how long would it last?  Should I go with the Lemforder?
P.S. I'm also thinking of replacing the oil cooler o-rings at the same time.  Worth it or best to leave them be?
i wouldn't touch the oil cooler unless its leaking. The mount...at least look at it. If you are doing the WP. you should pull it anyway. Tell us how it goes
