Old 06-13-2019, 10:37 AM   #248
MaddogsMotorSports
keyless entry not working
So I changed my power sorce to one that is 12v constant and same thing the after 15-20 seconds the keyless remote will not unlock the doors. You can hear the relays in the after market unit clicking but the doors will not unlock however for some reason I can pop the trunk??
There's your problem.
The seats are powered by the "consumer switched off" circuit. It's a circuit that supplies power to peripheral devices like seats and mirrors. When the car is off and doors closed, this circuit goes inactive after 10 minutes or so and stays that way until a door is opened. When you lock the car, the circuit goes inactive within 10-15 seconds.
In other words, the car is cutting power to your aftermarket keyless entry unit. I suggest getting constant power at a known good source, such as the current distributor.
MaddogsMotorSports is offline   Reply With Quote
