Old 06-13-2019, 06:20 AM   #1
Topless
Track rat
Topless's Avatar
Originally Posted by bbiela View Post
Opinions, please.
I recently got a set of M030 sway bars for my 986S. A local shop recommended installing only the rear and see how that affected the handling of the car before deciding to install the front. The car is a DD and used for AX and DE's. Should I install just the rear or should I install both?
Thanks for your thoughts.
This is what I did on my 986. It reduces understeer a bit and allows the car to rotate more easily without getting too slap-happy. Depending on the exact tire sizes and compounds you run it may be the right move. I ran mostly 225/245 NT-01 and balance was good.
