Old 06-12-2019, 05:39 PM   #5040
piper6909
piper6909's Avatar
I finally put my interior back together after dyeing the console and a bunch of other black plastic stuff that had that worthless coating.
Also changed the air filter and cabin air filter. Which leads me to question #1: Does anyone know where this oil residue on the intake tube came from?
My first thought was that it came from the PS pump reservoir, but the cap looks dry.
Then I tried changing the drive belt, but the replacement was slightly too short. I had the tensioner bottomed out and I made sure the belt routing was correct and it sat correctly on the pullies. The last pulley I would have put it on was the idler pulley next to the tensioner. I could probably force the belt, but I was afraid since the tensioner was bottomed out, there's no telling how much tension would be on the belt (the spring tensioner is supposed to put a certain about of tension, but the spring won't do any good if it's totally bottomed out). That made me concerned about having too much tension on the water pump. Which, BTW, I will replace VERY soon because when I had the belt off, I noticed a tiny amount of play.
Question #2: Has anyone ever had this issue with a Gates K060832 belt?
EDIT: So I found my own answer to this. the Gates 832 belt is 2113.28 cm long. The belt should be 2115cm. So I wasn't crazy, the Gates belt IS just a little too short. Not recommended, even though ******************************** said it fits.
Question #3: Which brand T-stat is recommended? I know Pierberg is the recommended pump, but I haven't found what's recommended for the T-stat, except going with a 160.
And last question: While I'm replacing the WP and T-stat, is there anything else I should do while I'm in there?
Thanks in advance!
piper6909 is online now   Reply With Quote
