I'm not sure a 2.7 will be much if any less work than a 3.2. you still need to active the resonance tube, you still need to convert back to the cable throttle body, and you might run into issues with the ecu.
If you're thinking about a 2.7, I'd just find another 2.5. The difference in power is negligible.
I'm so happy that I went with the bigger engine, really ups the fun factor.
