Old 06-11-2019, 07:45 AM   #2
ndfrigi
Good you did the rear first because front is more easier to replace the struts. Meaning, it will be lot easier for you since you did the harder side.
I replaced mine all 4 corners with bilstein also last year. Also, you may want to mark with a sharpy your various adjustments/bolts so u can install it back almost same alignment before removal. I did that and when time for actual alignment, there is only minor adjustment done by the alignment guy.
ndfrigi is offline   Reply With Quote
