Old 06-08-2019, 06:18 AM   #11
AZ986S
AZ986S's Avatar
Originally Posted by Heater Guy View Post
What Pre Pressure are you using in your Accusump? Gauge pressure.
Hey there, if you mean air preload pressure, then I use 15 psi now. Used to go with 7 psi but found that 15 psi works better.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
