Old 06-07-2019, 06:12 AM   #2
JFP in PA
Originally Posted by flmont View Post
I have heard a couple people say they have found a dual row IMS in a 2000' yr boxster 2.7,..if that is the case could you install a 99' model yr Bearing in a 02' using the snap ring process or is it likely they have a single row with a spacer and not the true double row bearing. just curious if its possible,..Thanks
The 2002 engines were all single row IMS bearings without any spacer; the IMS shafts are different between the single and dual rows. You cannot put a factory dual row bearing into a single row shaft.
