Old 06-06-2019, 10:55 AM   #21
dsjwilson
Hi TtT, since you have both a manual, and a Tip, do you know the correct part number for the Tip hose? If so, can you update your post, inserting the additional info showing the correct part number (and Tip vs. Manual designation), in a different font color. It would be a great resource for future searches. Either way, thank you for putting up all the info in this post, very helpful.
Originally Posted by tonythetiger View Post
Keeping in mind that the hose from water pump is different for the tiptronics, found this in another post and it has me on my way; Manual 986 Boxster S:
1 900-123-144-30 Crush Washer/Sealing Ring for Coolant Drain Plug (10 X 14 X 1 mm), Boxster/Boxster S (1997-04)
1 996-106-222-17 Water Hose to Water Pump (3-Way Hose), Boxster/Boxster S w/Manual Trans. (1997-04) (Purple Arrow)
1 996-106-501-07 Water Hose to Water Flange at Oil Pump Housing (Large Hose), Boxster/Boxster S (1997-04) (Orange Arrow)
1 996-106-502-06 Water Hose to Water Flange (Large Hose), 986 Boxster/Boxster S (1997-04) (Green Arrow)
1 999-512-609-09 Hose Clamp 32 x 12
2 999-512-589-09 Hose Clamp 25 z 12
2 999-512-594-09 Hose Clamp 53 x 12
2 999-512-668-09 Hose Clamp 49 x 12
dsjwilson is offline   Reply With Quote
