Originally Posted by tonythetiger
Any advice, strike that, part numbers and diagrams for the rubber hoses in the cooling system. There are about a dozen and I can’t figure out what I want cruising around the bet. I have 2001 and 2002 Boxster 3.2 S, one is a tip and the other manual. Hoses differ a little.
Every other car I’ve had, I could get parts diagrams and could figure it out on my own. Even the dealer parts counter is challenged.
Anyone else figured this out, I promise I’ll share
Keeping in mind that the hose from water pump is different for the tiptronics, found this in another post and it has me on my way; Manual 986 Boxster S:
1 900-123-144-30 Crush Washer/Sealing Ring for Coolant Drain Plug (10 X 14 X 1 mm), Boxster/Boxster S (1997-04)
1 996-106-222-17 Water Hose to Water Pump (3-Way Hose), Boxster/Boxster S w/Manual Trans. (1997-04) (Purple Arrow)
OR
1 996-106-522-04 Water hose to water pump (4-way hose), tiptronic (2000-2004) (Purple Arrow)
*(1997-99) use 996-106-222-16
1 996-106-501-07 Water Hose to Water Flange at Oil Pump Housing (Large Hose), Boxster/Boxster S (1997-04) (Orange Arrow)
1 996-106-502-06 Water Hose to Water Flange (Large Hose), 986 Boxster/Boxster S (1997-04) (Green Arrow)
1 999-512-609-09 Hose Clamp 32 x 12
2 999-512-589-09 Hose Clamp 25 z 12
2 999-512-594-09 Hose Clamp 53 x 12
2 999-512-668-09 Hose Clamp 49 x 12
