Hi All,
Just checked the TEMP sensors
Both the intake air temp, the cooling water temp , the engine compartment temp and the oil temp is around 20 deg C , when the car has been standing over night ( the same as the ambient temp.
As soon as I start the car they starts to climb, Water and oil fastest intakeair temp is climbing slower together with the enginecompartment temp
Temps actually looks fine, and according to the heat up of the engine.
For the vacuum there is no significant resistance inn removing the oil cap not cold nor hot?
If I start the engine from Cold ( it hs been standing over night) without touching the gas pedal it stalls and dies, on the 6-7 attempt it starts running erratically at 500 rpm and after 10-20 seconds it increases to 900 rpm and runs fine.
When it warms up it idles steady at app 750 rpm.
If I at the cold start applies the gas and takes the rpm to 1500 RPM and keep them there for a few seconds then it will immediately idle at 900 RPM when I let go.
In general the car runs fine , no oil consumption , nice and clean acceleration, gas milage is app 10 km/liter
as soon as the car has been started I can restart it without touching the gas??
can it be bad spark/s , Coils acting up when cold??
BR
Kim
