Old 06-05-2019, 12:04 PM   #3
Anker
If you have PSM there is a possibility that the different wheel diameter will confuse it and cause interesting things to happen. As a rule, the outside diameter of the wheel should not change, unless you do so for all four wheels. PSM uses rotation sensors in the wheels to determine whether they are slipping.
A 245/40/17 has a smaller outer diameter than a 255/40/17.
1941 Dodge Luxury Liner Coupe
