More than the size difference I would not use your friend's rear tires with your fronts unless they were all the same brand and model. Also your friend's tires should have a manufacturing date that is not more than 6 years old, the tires should not have any dry rot and should have a decent amount of tread left. Hopefully someone else will advise you on the size difference.
