Old 06-04-2019, 08:47 AM   #4
Cunningr
Cunningr's Avatar
Ok went to pedros site check in instructions but sniping or bending pin 18 only makes it where you can move the top up or down while in motion and hand brake light on.
However, on rennlist i did see a way to solder a jumper as well that will bypass the ebrake, but as PW points out best fix is swap the micro switch. There only like $20 if i remember correctly.
Ok this link goes to a thread with a vid on how to bypass speed and brake, might take a look.
https://www.renntech.org/topic/48509-986-emergency-brake-bypass-for-top-raising/
