Originally Posted by Quadcammer
use the oem Pierberg composite impeller pump.
I'd consider doing the two big coolant hoses that run up to the radiators.
yep, the consensus seems to be pierberg...adds money to the job, but figure Ill follow that advice. Which hoses, are there part numbers out there? THIS IS THE 3.2 S MODEL (BOTH OF THEM)
The hoses do worry me since these are nearly 20 years old. are some more prone to failure then others?
