Originally Posted by PaulE
Sounds like a weight to me too unless you hit a large pothole and bent a rim or a belt slipped inside the tire, which is rare but can happen.
Modern Hi-Performance tires are not prone to belts slipping.
I'm guessing the alignment shop did not do a proper alignment, the 1st step is to inspect for excessively worn parts. Or the steering rack is loose etc.
