Old 06-03-2019, 06:13 AM   #29
winter.k
winter.k's Avatar
Originally Posted by rfuerst911sc View Post
j911brick last night I positioned the pipes by eye to see how they fit . This is on a S muffler . To get the pipes roughly in the center of the exhaust tips the pipes that will go into the inlet pipes is about 3/4 of the ways on the inlet pipe and a 1/4 of the ways into the weld of the inlet pipes . Does that sound about right ? So the hole saw has to cut through some of the weld of the inlet pipes to the muffler case ? Any chance you have a pic or two of where the pipes go into the inlets ? Thanks
I have same question... I'm glad rfuerst911sc brought it up.
I also have a set of these from j911brick I have been planning to install (S version). When I test fit them the seemed really tight (or close) to the weld seam on the main muffler. I was assuming they would plumb in perpendicular to the inlet and outlet tubes, but maybe not.
j911brick, I trust you figured out the best fit - please confirm. Thanks.
winter.k is offline   Reply With Quote
