Old 06-02-2019, 05:31 AM   #19
Firstboxster
FINALLY FIGURED IT OUT!!!!!!
Decided to change out rotors - thought maybe one was warped. Couldn’t believe what I found. The right rear hub flange was not allowing the rotor to “seat” correctly so it was cocked just a little bit. Took it off and checked the old one...same thing. Ground the edges of the flange just a touch, and the rotor sat perfectly. Shake is gone! Car is smooth as silk!!
So all the front end work, struts in front and rear, while needed - didn’t smooth out anything. Kept checking alignment, tire balance - would all be perfect but when wheels were put back on, that right rear would be cocked just that little bit and no one would think to check it. Thanks to everyone for all the advice and suggestions! If you’re one of the guys having the same issues - check your rotors and make sure they seat correctly
Firstboxster is offline   Reply With Quote
