Hey guys, the rear bumperrettes are to stop 'soft' rear end collisions correct? Since the engine is in the back .. that makes sense.
Two questions though:
1. when you take off those bumperettes, is there just a metal 'tube' there?
2. is it possible to 'cut' those tubes (assuming a qualified metal shop does it) and just not have the bumperettes at all? Ofcourse you would need to 'patch' the rear bumpers, but it should be quite easy to do since its a flat surface.
Anyone done this before?
I have a white car and those black things are definately an eye sore.
Edit/Delete Message
