Old 05-30-2019, 01:02 AM   #1
hoahanhvinadry
VINADRY
Talking Buy Vinadry smart racks don't forget to refer to the following 3 samples
It is right to close Vinadry drying rigs, because this is the most famous brand of drying rigs today. But buying Vinadry drying rigs must also know which models are the hottest, typically you should refer to the 3 samples introduced below.
Vinadry GP941 drying rig
Vinadry GP941 smart drying rig is the hottest model of Vinadry drying rig 2019. This is the latest and most modern design at this time.
Listening to each other's ear-transmission families, turning the crank of this specimen is as light as it is even when it is loaded. As for the design, it is free and good standard.
The winch has a large, cylindrical design, on the face of the winch, the crank, the base are all created very sophisticated and sophisticated pattern patterns. Large exposures reach 60kg, the number of exposed holes is made up of 80 holes, equally evenly spaced.
Vinadry GP902 smart drying rig
Vinadry GP902 is also a Vinadry super product launched in 2019. Vinadry is an older version of gp941 but it is still noticed because of its beautiful, modern design, good drying capacity.
With a price of more than 1 million, buying Vinadry gp902 will be an excellent choice.
Vinadry automatic drying rigs AE711
Referring to Vinadry, it is impossible not to mention Vinadry AE711. If your family has a large enough drying space, consult Vinadry AE711 this product.
Vinadry AE711 is an automatic drying rig. Different from other models, turn the handle of the drying rig. In this model, users just need to press the available mode buttons on the controller.
The controller of the Vinadry AE71 drying rig will have 3 modes: lifting, lowering and stopping. Each time lifting, lowering the drying platform will lift and lower both bars at the same time. That is why we recommend that families have a bit of open space, so use this drying rig.
As an automatic model, the drying capacity of Vinadry AE711 is still quite good. Load capacity of the drying rig reaches 35kg, the number of drying holes made on 2 bars is 80 holes quite convenient.
Above, I help families to check out 3 samples of Vinadry's typical drying frames. If you love this brand, you should consult it for shopping.:ah:
hoahanhvinadry is offline   Reply With Quote
