Old 05-29-2019, 09:24 AM   #12
tonythetiger
Will there be cake?
tonythetiger's Avatar
Originally Posted by snottas View Post
I was able to stop the lights from blinking (4th to D) and the irregular gear changes by minor adjustment of the cable at the switch or at the gear lever. This only temporarily fixed the problem as the next time I went to drive I had the same problem which again could be temporarily fixed by adjustment but with the same outcome until I changed the switch.
Note:- the original problem was the lights blinking which occurred each time I drove the vehicle.
im pretty sure mine is related to heat...never does it cold, starts up after driving, happens quicker in hot weather and the fans run incessantly. I have a thermo to check the tranny temp ready for next time I drive the car and Im going to get into the engine bay this weekend to poke around, plus replace the coolant vacuum valve thingy. I expect my fix is the internal harness, but not sure yet.
