My shocks are worn out on my 2001 Boxster 98k miles. I'm planning on replacing some of the other suspension parts as its recommended here
https://www.pelicanparts.com/techarticles/Boxster_Tech/59-SUSPEN-Suspen_Overhaul/59-SUSPEN-Suspen_Overhaul.htm#Customer_Comments_Bookmark
The parts I'm planning on replacing:
All 4 shocks with shock mounts and bump stops
Control Arms
sway bar bushings
sway bar links
tie rod ends
I'm going to attempt to do this myself. Are there any other parts I should replace while I'm at it?
