Originally Posted by Anker
If you plan to do AX in a stock class you have to use OEM shocks. If you decide to drive in a modified class you will need to make all the allowed improvements in order to be competitive.
That depends on the organization you run with. SCCA Street Class allows you to change the shocks to whatever you want, but you must keep OEM springs.
