Old 05-26-2019, 08:00 PM   #25
Bravo 8
Appreciate the responses. I am going to let them do the water pump, pulleys/tensioners, coolant flush, brake fluid flush and AC vacuum and charge ($150). About $2500
I'm going to do brakes/rotors, plugs (they wanted $20 a plug), oil change, all filters, oil sending unit and of course the wiper blades. Top will be about $1500 installed. Auto top direct has been the best/recommendation I've found. $409 for a top/plastic window. I'll put decent tires on it but not going all out there. Should be about $800 installed. Then I detail the hell out of it!.....which I enjoy. May actually take a day off work to do it.
I'm not real happy they put a battery in and just started it. They said it sounded clicky for awhile until it got oiled....well, yea. I'll run this gas through it and then change the fuel filter so I don't have to do it twice. I think there's only a quarter of a tank in it if I remember. I'm a little concerned about that too. Hoping there's not garbage that gets picked up and clogs lines etc. Maybe run some injector cleaner through a couple times too. Never believed much in those "cleaners" in a bottle though. We'll see. I'm really excited though...after the shock wore off and I figured out what I can do.
Bravo 8 is offline   Reply With Quote
