First thing I would do is ignore what they've told you about the car. Do your own diagnostics.
IE: how do you know the cam has jumped? CHECK IT. easy enough to check your cam timing on this motor. Anker already pointed you in the right direction.
Be sure you're chasing the right problem, is all I'm saying.
Remember that it's quite possible that somebody already dumped the oil & changed the filter, so don't assume there either.
